Rookie checking in with a segmenting question.
Mandrake7062
PostPosted: Mon Mar 26, 2012 3:59 pm    Post subject: Rookie checking in with a segmenting question. Reply with quote
First off thanks tp Phil for coming up with this App, it's the cats meow!!
Second, thanks to Rich Art for steering me in this direction!!!
Long time stalker from the rendo forum Rich...
OK, the question:
If I have a bunch of connected greebles and segmented one part, then moved on,.
Later I decide to Shift D the segment piece, back to edit mode.
Is there a Ctrl key, to remove the segment lines and start over with a manual dissection, so to speak.
Thanks, Kenny
PostPosted: Mon Mar 26, 2012 5:15 pm    Post subject: Reply with quote
Wow, someone else just asked the exact same question!
Use Shift-D a second time to remove any previous cut lines. Details are here in the other posting ...
http://www.headus.com/phpbb/viewtopic.php?t=1110
Mandrake7062
PostPosted: Mon Mar 26, 2012 5:43 pm    Post subject: Reply with quote
Opps, I did scan the threads and had read a bunch of them..
That shift D, does not seem to undo all the green lines, but I will practice more, it just moved it back into place.. No sweat, I'll play more.. Maybe I didn't have the cursor over it or something like that.
Thanks.
PostPosted: Mon Mar 26, 2012 5:49 pm    Post subject: Reply with quote
"That shift D, does not seem to undo all the green lines"
Could be a bug ... which version are you using?
Mandrake7062
PostPosted: Mon Mar 26, 2012 6:04 pm    Post subject: Reply with quote
2.07.02 but I was probably the bug, I will test more. intensely into a piece so I'm afraid to screw around at the moment. Smile
