Liz_NZ
Posted: Wed Mar 07, 2012 7:54 pm Post subject: revolving an object in ed space |
hi
when i first load in my object from Maya, the MMB and RMB work the same as in Maya, however the LMB doesn't seem to work the same which is frustrating.
object revolves vertically ok, but not horizontally (left/right) on the pivot?
i notice after going into UV/3d space after cutting etc and coming back to the ED window seems to then work.
any ideas why?
thx
Posted: Wed Mar 07, 2012 8:37 pm Post subject: |
By default, UVLayout wont let you rotate something over so its upside down, so maybe you're hitting that limit somehow in combination with the Up setting being incorrect for your model.
Try setting the Display Up to "Free" so see if that helps.
Liz_NZ
Posted: Thu Mar 08, 2012 4:52 pm Post subject: |
the model is up the correct way in Maya, but loads upside down in the UV Layout
However, the FREE command fixes the problem - thanks  |
Posted: Thu Mar 08, 2012 6:21 pm Post subject: |
Great! It odd though that it comes into UVLayout upside-down; you might actually have it flipped over in Maya without realizing it.
