hotkey bugs, few working
rissta
PostPosted: Sat Sep 10, 2011 2:26 pm    Post subject: hotkey bugs, few working Reply with quote
I'm trying the demo and I've used headus in the past. The issue I'm having is pretty crazy. Hardly any of the hotkeys work. I can't cut with C. Sometimes I can hit G and enter to pop pieces out but then I cant weld with W. I recently had to install windows 7 again. Is there maybe a driver or something that Headus is dependent on to work properly?
Thank you!
PostPosted: Sun Sep 11, 2011 6:26 pm    Post subject: Reply with quote
Are you resizing the window after the mesh has loaded? On some OS/hardware configurations, the window resizing can get UVLayout confused about where the mouse pointer is inside the window, so things like C and W stop working.
If that sounds like your situation, make the window the size you want, then click the "Pin" button to the left of the "About UVLayout" button at the top of the GUI, and that saves the window size. You can then reload the mesh and hopefully the hotkeys will work as usual.
