UVLayout plugin for 2012. Does it work?
josh
PostPosted: Mon Jun 13, 2011 1:11 pm    Post subject: UVLayout plugin for 2012. Does it work? Reply with quote
Has anyone got this to work yet?
I made sure the path was set to pro version and my obj plugin was checked, but I get nothing when I click the run and send buttons, not even an error.
any ideas?
PostPosted: Tue Jun 14, 2011 2:47 am    Post subject: Reply with quote
Open up the MEL script window, and type this ...
uvlayout_run;
.. followed by the Enter key. Do you get any errors from that?
josh
PostPosted: Tue Jun 14, 2011 8:54 am    Post subject: Reply with quote
i get this error
// Error: Cannot find procedure "uvlayout_run". //
PostPosted: Tue Jun 14, 2011 5:34 pm    Post subject: Reply with quote
Sorry, I made a mistake! The command you need to type in is ...
uvlayout_open;
josh
PostPosted: Wed Jun 15, 2011 8:15 am    Post subject: Reply with quote
no errors
the gui popped up as well, but UV layout didn't open.
PostPosted: Wed Jun 15, 2011 4:48 pm    Post subject: Reply with quote
Edit the uvlayout_open.mel script and search for the uvlayout_run() function. Towards the top of that you'll see a debug variable being set to "0". Change that to "1", save, and restart maya. Type "uvlayout_open;" into the script window again and this time it should dump extra information. You can post that here and I'll see if I can work out whats going wrong.
jjk
PostPosted: Thu Jun 30, 2011 3:27 am    Post subject: Reply with quote
I am running maya 2012, the uvlayout plugin icons are showing on the shelf and i can select info and run the uvlayout program within the window it opens by clicking on run uvlayout button.
now if i select astandard maya polygon cube and the clickon send mesh i get this error : // Error: file: C:/Users/Unified/Documents/maya/2012-x64/scripts/uvlayout_open_mod.mel line 189: Could not save file "C:/Users/Unified/Documents/maya/projects/default/default/uvlayout/tmp6572.obj".
I did not have this problem with maya 2011 and below. I can export the cube or any other model using maya 2012 own obj export plugin with no problems or errors and import as well with no errors.
I hope some one can help.
thankyou.
PostPosted: Thu Jun 30, 2011 4:41 pm    Post subject: Reply with quote
The plugin is supposed to make its own temporary folder, but maybe that's not happened for some reason? So check that this folder exists and that you have permissions to create files in it ...
"C:/Users/Unified/Documents/maya/projects/default/default/uvlayout"
jjk
PostPosted: Thu Jun 30, 2011 9:14 pm    Post subject: Reply with quote
Thank you Phil that works.
And thank you for such a great progam and plugin.
stezza
PostPosted: Wed Aug 10, 2011 1:30 am    Post subject: Send button Reply with quote
I am having the exact same problem I do have the uvlayout folder which does have the temp data saved in it when I press the send button but will not appear in UVlayout UI.
I did rename the temp item with extenion .obj and it does load through UVlayout UI.
Any ideas as to what else could be causing this issue?
PS just tried it with Maya 2011 and works fine here so could it be to do with Maya 2012 hot fix2?
View user's profile Send private message MSN Messenger
