Aliastasia
Posted: Mon Feb 21, 2011 2:48 pm Post subject: More yellow |
When you press S over a selected shell, and do your flattening thing, are you supposed to be able to "un-yellow" that shell afterwards?
i.e I press S over a shell in UV view. The wire turns yellow. I press optimise, or any of the other flatteners, and flattening happens according to set parameters. Clicking the wire again turns the wire green with a yellow outline, but it won't give me black wire on green/red/blue mesh again, even when unselected?
/A |
Posted: Tue Feb 22, 2011 1:17 am Post subject: |
The 'S' hotkey is used for Stacking operations. If you're just flattening or optimizing, you don't need to use 'S', so skip that step and you wont end up with a yellow shell.
By the way, to get rid of the yellow highlighting, when the 'S' key stack menu appears, click on empty space to unpick the shell.
Aliastasia
Posted: Tue Feb 22, 2011 6:54 am Post subject: |
I like using it - it gives me a nice little mini-snap when I activate it, v handy on impossible wires
/A |
