cchomp
Posted: Thu Feb 10, 2011 6:51 am Post subject: import problem |
hi
I used uvlayout to unwrap my model but when I import it back into max there's a weird shadow problem
(one on left is imported, right is original)
just wondering what im doing wrong?
thanks  |
Posted: Thu Feb 10, 2011 5:34 pm Post subject: |
When saving the OBJ out of UVLayout, try using the "Update" button instead of "Save". You select the original OBj file, and UVLayout makes a copy of that with only the UVs modified; that will preserve all the other info such as normals and smoothing groups, which could explain the difference you're seeing.
Or alternatively, use the Max plugin ...
http://www.headus.com/phpbb/viewtopic.php?t=402
That makes it easy to move objects between Max and UVLayout, and it'll preserve a lot more than just normals.
