Posted: Mon Jun 24, 2024 11:33 pm Post subject: UVLayout v2024.01 now available |
Hello All,
UVLayout v2024.01 is now available for all users from ...
Changes to existing tools:
- Snap : Now while the Snap tool panel is stowed/hidden, any
active snap settings are temporarily turned off.
- File Selection Dialog : Split the files filter into a text
entry field for file name and an option menu for file type.
- Render : Added an option for JPG, TIF or PNG output.
- Edge straightening tool : Now use of the S hotkey to straighten
edges is mirrored if symmetry editing is turned on.
- Display Trace : Increased Max Rez to 8k.
Posted: Mon Jun 24, 2024 11:37 pm Post subject: |
Bugs fixed:
- Display Trace : Fatal error if loading a UVL file with all UVs
in negative space and a trace map defined.
- File Selection Dialog : Fixed a bug with directory access from
the / Desktop list. Also Desktop and shortcut files were shown
with 0 size in the file list.
- Symmetry Find : If Display Hide Seams in 3D was turned on,
then any picked edges were not shown. Picked edges on undropped
mesh in the 3D view were also not shown.
Installation changes:
- Windows : The headus engine is now a 64bit build, meaning larger
files can be processed. |
