Daf57
Posted: Mon Oct 22, 2018 7:34 am Post subject: UnDropping - need a complete reset. |
Okay - so looking for a button or maybe workflow suggestions for this issue...
I have existing mesh with UVs (from UVLayout) - I add some geometry to the mesh and re-enter UVLayout in edit mode. In the 2D Edit screen I can see the new geometric as blue - I undrop all the blue back into 3d Edit. In the 3D edit screen the mesh has a lot of seams that I did not intend. Shift+D for each and every (sometimes I add a lot of geometry - sometimes UVLayout adds seams for every edge) is a pain. So question is ... is there a complete mesh reset for the 3D editor - some method to reset the mesh (only mesh in 3D editor) with a single button?
Hope that made sense... thanks!
Daf |
Posted: Wed Oct 24, 2018 4:21 pm Post subject: |
If you load the OBJ with "New" selected in the load options, then all existing UVs are discarded.
But if you want to keep some, then yes, use Shift-D ... if you type it with the mouse pointer over empty space, then you'll be able to use the left mouse button to draw a box around all the shells you want to undrop.
That moves them from the UV space back "up" to the Ed space. Once there, you'll need to use Shift-D again, to join them all back together, if you want to select different seams.
Daf57
Posted: Fri Oct 26, 2018 2:49 am Post subject: |
Hey thanks! Drawing the selection box is what I needed! No more picking for days! Ha ha!
Daf |
