inconsistent results when flattening
michel
PostPosted: Thu Aug 16, 2018 2:39 am    Post subject: inconsistent results when flattening Reply with quote
I am fairly new to UV Layout so I am probably doing something wrong but I am having the following problem.
when I try to flatten the same object (the turret of a tank) using the Shift-F command I get totally different resullts.
Attached you'll find the UV map of the first attempt (UV layout correct flattening). Which is actually the result I am looking for.
In the first attachment you'll find the result of the 2nd attempt which is obviously not what I want.
In the 3rd attachment You find the ulv file.
How can I consistently get the first result?
pls help
kind regards
Michel
