How to transfert an UV from UV view to Edit mode
Der Duca
PostPosted: Sun Nov 22, 2015 1:18 am    Post subject: How to transfert an UV from UV view to Edit mode Reply with quote
Hi everybody,
sometimes in UV view you figure out there is something wrong in your UV (maybe you have to cut your UV uìin a different way to better unfold it). But how can you send again it on Edit view to make a new cut ?
Many thanks for a reply!
PostPosted: Sun Nov 22, 2015 4:56 pm    Post subject: Reply with quote
Shift-D will move a shell from the UV space back into the Ed space. It'll still have the same cut lines at that stage, so if you want to get rid of those, use Shift-D again when in the Ed space to start completely from scratch.
Look for the "undropping" video here ...
http://www.uvlayout.com/index.php?option=com_wrapper&Itemid=97
Der Duca
PostPosted: Thu Nov 26, 2015 1:52 am    Post subject: Reply with quote
Great h,
okay, understood,. Many thanks!
