menu tricks to activate pin selection
tikal
PostPosted: Thu Nov 28, 2013 3:36 am    Post subject: menu tricks to activate pin selection Reply with quote
hi guyz, i m testing using your software and it look to be very powerfull.
i have just a little issue about the menu logic.
what i need to do is pinning all the marked faces so that i can flatten with shift B only some faces.
well , as far as marking faces, i have no problem, i can move my mouse pointer on the faces pressing g.
but then to pin those faces is a hell.(for me for sure:)))
i succeded only once....prehaps i m tough in learning:)))
the button is p .
i notice that buttons work differently if mouse is on the shell or outside, but, which is exaclty the way i have to follow???
thanks in adavance for my silly quesiton!!!
mat
PostPosted: Thu Nov 28, 2013 6:09 pm    Post subject: Reply with quote
So after marking your faces, move the mouse pointer so its away from any shells ... still inside the graphics window, but not over any geometry. Tap the G key to bring up the marking menu, then tap the P key to pin all marked polys. Use G then Shift-P to unpin marked faces.
