alter5
Posted: Thu Oct 03, 2013 2:13 pm Post subject: Complex Ojects |
Is it possible to somehow automatically unwrap such little/complex parts the quality doesnt matter just that i dont have to manually cut this things
thanks in advance |
Posted: Fri Oct 04, 2013 12:54 am Post subject: |
The "Segment" tool in the Pro version might help ... its main use is for more architectural blockish type shapes (eg street scapes), but even if its doesn't do a fantastic job, the results can be edited, and it might be quicker than starting purely from scratch.
alter5
Posted: Fri Oct 04, 2013 2:50 am Post subject: |
so theres no for example fast rectangular selection? |
Posted: Fri Oct 04, 2013 6:25 pm Post subject: |
Because its all triangles, the usual edge loop selection tools wont work that well. Did you try the Segment tool?
alter5
Posted: Sat Oct 05, 2013 1:04 am Post subject: |
yes i did but its still kinda like i dont really manage to select all of them at once so i just wonder if there was an ruffer selection tool^^ |
Posted: Sun Oct 06, 2013 6:31 pm Post subject: |
If you aim the pointer at nothing then tap G, you can then use the left mouse button to draw out a rectangle. Or if you want to select everything, aim the pointer at nothing again and do G then S to swap the select state of all polys.
