SuperSheep
Posted: Fri Nov 30, 2012 4:51 pm Post subject: Straighten Cut lines ? |
How can I straighten cut lines and keep them straight when dropping it into UV mode ? |
Posted: Fri Nov 30, 2012 6:32 pm Post subject: |
If you're doing cylinders and pipes, you should watch the "UVLayout-Rectangles-and-Pipes" video at ...
http://www.uvlayout.com/videos-advanced
General edge straightening though can be done with the I and K hotkeys, and you can see that in the "UVLayout-Interior-Straightening" movie. In recent releases, the I and K keys also work on boundary edges, not just internally.
SuperSheep
Posted: Tue Dec 04, 2012 6:44 am Post subject: |
headus wrote: | If you're doing cylinders and pipes, you should watch the "UVLayout-Rectangles-and-Pipes" video at ...
Phil, I'm unable to successfully flatten this object, without it becoming a tangled mess in the UV editor, I haven't watched the video, yet do you have any suggestions ? I have one cut line on the object.
Posted: Tue Dec 04, 2012 3:30 pm Post subject: |
Maybe try cutting it up into 4 quarters, flatten each of those, then weld the pieces back together for more flattening.
SuperSheep
Posted: Wed Dec 05, 2012 2:23 pm Post subject: |
headus wrote: | Maybe try cutting it up into 4 quarters, flatten each of those, then weld the pieces back together for more flattening.
That can work, I can't flip UV islands so I can align and merge islands together
Posted: Wed Dec 05, 2012 5:18 pm Post subject: |
The problem is that those protrusions are a lot of geometry trying to fit into a small square. If you're happy with seams, detach them from the rest of the wheel and flatten separately. If you want it all as one piece, I'd still detach and flatten them separately, then scale them down so they will fit back into the square hole they came out of and weld them back in.
See this video for an example of the UV scaling process ...
http://www.headus.com.au/doc/uvlayout-expert/videos/UVLayout-Local-Scaling.mov
SuperSheep
Posted: Fri Dec 07, 2012 10:44 am Post subject: |
headus wrote: | The problem is that those protrusions are a lot of geometry trying to fit into a small square. If you're happy with seams, detach them from the rest of the wheel and flatten separately. If you want it all as one piece, I'd still detach and flatten them separately, then scale them down so they will fit back into the square hole they came out of and weld them back in.
Probably the best solution.
How can I have matching weld edges always to "red" so I know which UV islands to match up to, without selecting the UV edge manually and finding the edges. |
Posted: Fri Dec 07, 2012 5:25 pm Post subject: |
If you W tag an edge, you can then use M to move that shell so its right next to its adjacent shell. Shift-M is probably more useful though ... it moves the other shell so its next to the one you're looking at.
SuperSheep
Posted: Fri Dec 07, 2012 6:31 pm Post subject: |
headus wrote: | If you W tag an edge, you can then use M to move that shell so its right next to its adjacent shell. Shift-M is probably more useful though ... it moves the other shell so its next to the one you're looking at.
I'll try that out, something to speed up UV'ing this object. |
