dustinbrown
Posted: Wed Sep 26, 2012 12:14 pm Post subject: Using I to tag straight edges |
It seems to me I used to be able to press I to tag a single edge. Now it tries to guess and tag an entire loop when I press I. This is no good. I used to press I on opposite ends of a segment I wanted to straighten. This "bookended" the segment then I pressed (I think) Shift+I in the middle area to tag the stuff in the middle.
The point is, you could get a lot more surgical with your edge tagging. Feels like I lost that ability. |
Posted: Wed Sep 26, 2012 5:59 pm Post subject: |
For consistency across the hotkeys, "I" now functions like "C", with the same edge loop detection and selection functionality. If you want that surgical precision back, try the new "D" mode after 0/1/10 in the Edit panel. That lets you press and hold "I" on the first edge, then drag the mouse pointer in the direction you want to select.
dustinbrown
Posted: Sun Sep 30, 2012 11:19 am Post subject: |
I will definitely try that. Thanks Phil! |
Hank2956
Posted: Thu Jan 10, 2013 9:46 am Post subject: |
I ran into the same problem, glad I found a fix. Working as usual now, thanks! |
