mm
Posted: Wed Apr 25, 2012 5:44 am Post subject: Ubuntu 10.04 x64 install problem |
Hi!
I downloaded demo and when I tried to run uvlayout I got segmentation fault error.
This is ldd uvlayout output:
linux-gate.so.1 => (0xf7731000)
libm.so.6 => /lib32/libm.so.6 (0xf76ef000)
libcrypt.so.1 => /lib32/libcrypt.so.1 (0xf76bc000)
libgomp.so.1 => /usr/lib32/libgomp.so.1 (0xf76ae000)
libpthread.so.0 => /lib32/libpthread.so.0 (0xf7695000)
libc.so.6 => /lib32/libc.so.6 (0xf753c000)
/lib/ld-linux.so.2 (0xf7732000)
librt.so.1 => /lib32/librt.so.1 (0xf7533000)
Why uvlayout isn't working ?
Thanks |
Posted: Wed Apr 25, 2012 4:43 pm Post subject: |
Do you have the 32bit compatibility libraries installed? Run this to make sure ...
sudo apt-get install ia32-libs
Also, you may need to use the motif libraries supplied with the UVLayout installer. Red the following for info on that ...
http://www.uvlayout.com/openmotif/
