crispalomino
Posted: Sat Feb 11, 2012 12:41 am Post subject: Blue Lines unselectable |
Hi, trying to figure out why I can't select any blue lines to cut for these sections. I am wondering if it is the tris on these surfaces.
Does the blue indicate an error?
Thanks. |
crispalomino
Posted: Sat Feb 11, 2012 1:23 am Post subject: |
Is the what is happening in mine, too? http://www.headus.com/phpbb/viewtopic.php?t=1082
Also, why when I do something like a cylinder, the outer edge can be mapped so that it is flat (seams on outer edges and one across to split the ring open), but if I do a ring on the inner part of the cylinder, they map rounded. What I would want is to have them flat like the outer first ring I cut.
Thanks. |
Posted: Sun Feb 12, 2012 6:54 pm Post subject: |
"Does the blue indicate an error?"
No, it indicates an edge or seam in the geometry. By the looks of it, if the blue edges go all the way around, those faces would be detached as separate pieces already. Try using Space-MMB to move them apart.
"but if I do a ring on the inner part of the cylinder, they map rounded."
Can you attached a picture?
