does red and blue lines on edges indicate a problem?
Zaynt
PostPosted: Wed Jan 19, 2011 8:43 pm    Post subject: does red and blue lines on edges indicate a problem? Reply with quote
Hi, I am uv-mapping a 3d-model for the first time and I was wondering if the led and blue lines that appear on the inner edges of my uv-shell indicate a problem?
PostPosted: Wed Jan 19, 2011 8:59 pm    Post subject: Reply with quote
That's a feature actually ... its called "webbing", and is applied automatically to holes when you use Shift-B on an unflattened shell. You can add and remove webbing with the T and Shift-T hotkeys.
Without webbing, holes sometimes collapse when a shell is optimized. This is because all the polys are pushing out usually to make themselves the correct flattened shape, and if there's a hole, it will shrink because that's somewhere for the polys to expand into.
With webbing, the holes push back, retaining their shape.
SLI_Fallen
PostPosted: Thu Jan 20, 2011 6:34 am    Post subject: Reply with quote
I was actually having some problems with that recently (webbed holes collapsing on themselves) so I just ended up pinning them like telling a dog to SIT! STAY! lol. So I cant exactly look back/recreate/explain what happened (this time) but i'll be sure to if it happens again.
PostPosted: Thu Jan 20, 2011 4:48 pm    Post subject: Reply with quote
"but i'll be sure to if it happens again. "
Yes, please do! I've never seen it happen myself, so I'm really curious to know what unusual geometry you might have had there to make it happen.
