Sneak peek of multi-view mode
PostPosted: Tue May 11, 2010 12:29 am    Post subject: Sneak peek of multi-view mode Reply with quote
Hello All,
Here's a sneak peek of the new multi-view mode that'll be in the next release of UVLayout. You can create any number of window panes, and inside each of those can be different UV or 3D views of the loaded mesh. Any editing of the UVs will be displayed in the 3D textured views also.
r_knightly
PostPosted: Tue May 11, 2010 1:34 am    Post subject: Reply with quote
awesome. finally I can keep a texture preview window open while i work
SLI_Fallen
PostPosted: Fri May 14, 2010 6:15 am    Post subject: Reply with quote
Will the embedded views be able to be "undocked" and moved, to say a second monitor?
PostPosted: Fri May 14, 2010 5:27 pm    Post subject: Reply with quote
Not initially. To keep it simple to start with all the windows are inside the single main window. Once I get that working though I'll look at adding proper independent windows.
SLI_Fallen
PostPosted: Sat May 15, 2010 3:09 am    Post subject: Reply with quote
No worries Phil! Was just curious is all. Excellent work as always.. Cool
