how to fix odd faces? Help!!
UV
PostPosted: Tue Mar 23, 2010 7:50 am    Post subject: how to fix odd faces? Help!! Reply with quote
How to fix odd face , i enable "clean" in load option but my model look something like this .. please help how to fix it.
Best regard
PostPosted: Tue Mar 23, 2010 7:38 pm    Post subject: Reply with quote
Can you email me that OBJ file? It looks like the "Clean" is really confused about the geometry, so I'm keen to see what your original file is like.
UV
PostPosted: Wed Mar 24, 2010 2:57 am    Post subject: Reply with quote
i've send the file to you already.
thank you.
hope to see your reply soon
best regards
UV
PostPosted: Wed Mar 24, 2010 6:23 pm    Post subject: Reply with quote
Thanks for sending the OBJ file!
Here's a couple of the "odd" faces that UVLayout is finding ...
f 466/150 473/150 474/150 466/150
f 466/150 477/150 466/150
The numbers before the slash are indexes into a list of XYZ vertexes, and the duplicated indexes there are what UVLayout is finding and the cleanup is creating the blue edged holes.
I should be able to get the clean function to fix these up in a nicer way, but in the meantime, check if your 3d modeling application (3ds max?) has its own mesh clean-up tools. It needs to look for and fix duplicated vertexes, and then you should be able to load that mesh into UVLayout without any errors.
PostPosted: Wed Mar 24, 2010 7:38 pm    Post subject: Reply with quote
Actually, UVLayout's clean is already deleting duplicate indexes, so there more going on in the problem areas than just that.
What I suggest is having a closer look at the polys in the three problems areas (see below) in your modeling application. Grab vertexes and move then around to see if you can work out why the topology in those areas is messed up. You could also just delete those polys and add new ones.
UV
PostPosted: Thu Mar 25, 2010 2:42 am    Post subject: Reply with quote
thank you for your replied
I'll test it.if it's done ill let you know.
best regard
UV
UV
PostPosted: Thu Mar 25, 2010 5:26 am    Post subject: Reply with quote
ok,everything is clear but only has a blue seam in the mouth please look at this picture. that mean i should fix the vertexs again?
best regard
UV
PostPosted: Thu Mar 25, 2010 6:17 pm    Post subject: Reply with quote
Blue edges indicate holes in the geometry. If you look at that from the inside (see below) you can see the missing polys. You can still flatten this mesh out to create UVs, so having holes like this isn't necessarily a problem.
UV
PostPosted: Fri Mar 26, 2010 2:21 am    Post subject: Reply with quote
o.,ok i got it.
that means i can create UVs now,right? Laughing
thank you very much to figure my problem out.
Best regard
UV
UV
PostPosted: Fri Mar 26, 2010 8:49 am    Post subject: Reply with quote
hi, i would like to use symmetry but it has some problem like this?
best regard
UV
PostPosted: Fri Mar 26, 2010 4:53 pm    Post subject: Reply with quote
Have a look at the image below ... its a close-up of the two wrists.
The green marked quad is where the symmetry matching has stopped because the topology is different on each side. What I think has happened is that you originally had a 5 sided polygon there (I've outlined it in red); something has turned that into a quad and a triangle, but the division has been done differently on each side (blue dotted line).
If you look at those parts of the model in your application and see a 5 sided poly, then its your applications OBJ exporter that's doing it; there might be options to stop it from doing that?
UV
PostPosted: Fri Mar 26, 2010 5:46 pm    Post subject: Reply with quote
thank you,but in mine it just only 4 sides but the thing you said is it's different on each side so i have to fix each side to match other side.that the point to fix ,right?
best regard
UV
PostPosted: Fri Mar 26, 2010 5:59 pm    Post subject: Reply with quote
Yes, you need to move that dividing edge so that the left side is a mirror image of the right side. In the image below I've drawn in a black line where you need to move the edge to in the right wrist.
There's probably going to be other polygon pairs just like this in other places, but just keep running the Symmetry Find and looking for the green marked polys to find the bad area.
UV
PostPosted: Fri Mar 26, 2010 6:10 pm    Post subject: Reply with quote
ok,thank you.i'll fix it when i get back from school. Very Happy
best regard
koko
UV
PostPosted: Sat Mar 27, 2010 3:01 am    Post subject: Reply with quote
it's clear now and ready to create symmetric uvs . Laughing thank you
best regard
UV
