weld gaps and copy uvs
PostPosted: Thu Feb 04, 2010 3:29 pm    Post subject: weld gaps and copy uvs Reply with quote
I've continued to test the weld gaps option on high threshold (up to 99%) but am not getting it to work on shells.
Could adjusting the threshold for segmenting marked polys help avoid these gaps?
When using copy UV's option the camera seems to be locked, which means that I cannot use it on some meshes. Would it be possible to have a free camera?
PostPosted: Thu Feb 04, 2010 5:36 pm    Post subject: Reply with quote
Send me an OBJ with the geometry that doesn't segment nicely and I'll have a look at it.
"the camera seems to be locked,"
Yeah, that's because the usual LMB to spin the camera is used to pick edges. But if you hold down Alt (Maya style) then you can change the camera while in picking mode.
