multi view window
UberMonkey
PostPosted: Sun Feb 18, 2007 11:50 am    Post subject: multi view window Reply with quote
i think being able to choose between a single view and multi view window like other 3d aplications would really help improve workflow by not always having to jump from one view to another.
PostPosted: Sun Feb 18, 2007 11:02 pm    Post subject: Reply with quote
OK. I guess I'm used to the single view mode now so don't find it a problem.
One hotkey you might have missed is "Home"; point the mouse pointer at any part of the mesh and hit the Home key to focus in on that area. Aim the pointer at the background and hit Home to zoom back out to see the whole mesh. By using the Home key you can quickly move around the mesh, quicker I like to think than if you had your usual top, front and side views.
Locke
PostPosted: Mon Feb 19, 2007 1:19 am    Post subject: Reply with quote
I'm going to go out on a limb and guess he's suggesting multiple windows as in two views that are in a combination of Edit, UV, or 3D, rather than a top, right, front, camera setup.
PostPosted: Mon Feb 19, 2007 1:24 am    Post subject: Reply with quote
Ahhh, of course! That makes more sense ... seeing both the UV and 3D views at the same time might be handy. Might be tricky to do too, but I'll add it to the list!
peri
PostPosted: Wed May 28, 2008 4:19 am    Post subject: Reply with quote
Suggestion seconded Smile
