wr_uk
Posted: Wed Sep 12, 2007 7:32 pm Post subject: Dongle recognition through a Virtual Machine! |
Hi
I have a new iMac intel core 2 duo and I'm running Maya and UVLayout through a virtual PC type of software called VMWare Fusion Maya works fine. UVlayout installed OK and VMWare Fusion sees the dongle but the it doesn't seem to recognize it and therefore will not connect it.
It see it as: aladdin knowledge HASP HL 2.16
I know the dongle is fine because I just tested it on a PC and I know the USB port is working in this setup through VMWare Fusion because I just tested a Printer.
So why cant VMWare Fusion connect the dongle?
If I can get it to connect I'm sure UV Layout will have no problem activating the key
Any body else had a similar problem?
Is there a solution by still using VMWare Fusion Virtual Machine
thanks
Wayne |
Posted: Wed Sep 12, 2007 8:09 pm Post subject: |
"So why cant VMWare Fusion connect the dongle?"
I'm checking with my dongle suppliers to see if they support Fusion or not.
Does my licensing GUI thing give you an Ether ID? I can generate a temp license for that if you want to see if UVLayout runs or not.
wr_uk
Posted: Thu Sep 13, 2007 7:58 am Post subject: |
1 sec
wr_uk
Hi phil
Temp license would be good for now
The Ether ID it gives me in license manager is 2956f75c
Thanks
Wayne |
Posted: Thu Sep 13, 2007 6:21 pm Post subject: |
Temp license for that Ether ID has been emailed.
Oh, and here's a reply from the dongle tech support people ...
Quote: | Your customer needs to have the HASP HL driver installed in the host operating system. If it's not already, then this is the problem.
Since fusion is a Windows emulator for Macintosh, he will need the appropriate Mac driver. You can download these drivers from http://www.aladdin.com/support/hasp/vendor.aspx
Fingers crossed!
wr_uk
Posted: Sun Sep 16, 2007 7:38 pm Post subject: |
Hi Phil
The temp key works fine...so no worries there!
Ive installed the Software HDD_Installer_ MacOSX.dmg as per the link above but I still can't get the key connected...even thought Windows running through VMware Fusion sees the key!
Do you know if anybody else is running through a similar setup ie through parallels?
This maybe an alternative I would consider
Thanks
Wayne |
Posted: Sun Sep 16, 2007 8:32 pm Post subject: |
"The temp key works fine...so no worries there!"
I even had my doubts about that working, so thats excellent news!
" but I still can't get the key connected..."
OK, I'll email some info on further diagnostics tests you can run. It'll maybe tell us if theres still a driver problem, or if its a problem in UVLayout itself.
"Do you know if anybody else is running through a similar setup"
No, you are the first I know of. One of these days I'll bite the bullet and will get a mac here at headus, then I'll be able to a) test UVLayout under Fusion etal. and b) start work on a native port.
nate.reeves
Posted: Sat May 03, 2008 5:53 pm Post subject: |
Just wanted to note that I've got the same issue here.
Just downloaded the newest build of UV Layout and
trying to run through Fusion- fusion sees the dongle
but it doesn't seem to want to take.
System specs:
Fusion 1.1.2 / Windows XP Professional
MacPro Dual QuadCore Xeon 2.8
Leopard 10.5.2 |
nate.reeves
Posted: Sun May 04, 2008 8:48 am Post subject: |
Yeah actually it was after reading that post I decided
to get Fusion to run UVLayout at home.
I've got the dongle drivers installed on both systems,
When I select it through Fusion the light on the dongle
turns off and back on once, the 'New Hardware' dialog
showed up - but UV Layout is still displaying
Dongle: not found.
I will keep working with it and post any progress here. |
nate.reeves
Posted: Thu May 08, 2008 12:35 pm Post subject: |
Just a brief update:
I still haven't gotten the UVLayout HASP to
work at all in my XPsp2 install on Fusion.
I've now tried Fusion 1.1.1, 1.1.2, and am
currently working under the 2b1 version.
Of interest, I tried plugging in my HASP
key for BiaS Peak - and was able to
connect it. Shows up as HASP HL 3.21.
I don't know what the difference is between
this HASP and the v2.16 HASP I have
for UVLayout, but it seems to be behaving
a little better...
still at it- |
nate.reeves
Posted: Mon May 19, 2008 7:37 pm Post subject: |
--edit--
I decided to give it a shot under parallels as opposed to fusion,
who knows - maybe they hardware drivers are different right?
when I insert the dongle under parallels I get an error window
saying the dongle is in use by another application. I couldn't
identify the process under Activity Monitor. Instead I downloaded
the HASP drivers for OS X from aladdin (google HASP OS X)
and instead of installing them I uninstalled them. Now everything
works fine, in both Parallels and Fusion the dongle connects
and stays connected.
I do have a HASP-enabled app on OS X (Peak Pro) but I
don't use it nearly as much. That would be the main consideration
on this workaround. If you're using bootcamp it wont be an
issue, but if you're using a dual-OS environment this is a
real + working solution.
MacPro 2008 w/OSX 10.5.2 / Fusion b2.0.1 / XP sp2 |
Posted: Tue May 20, 2008 5:06 pm Post subject: |
Many thanks for sharing your experience. It seems like getting the HASP dongles to work under the virtual machines is a bit of a black art, but is at least possible. We do still plan to develop a native OSX port though, and hope that'll happen before the end of the year.
