hey i have a problem with the optimize mode
Scubasteve
PostPosted: Mon Apr 07, 2008 8:10 pm    Post subject: hey i have a problem with the optimize mode Reply with quote
I am running dual monitors on NVIDIA GeForce 7300 LE. When i go to optimize it comes up blank. I can view it in 3d mode just cant see the uvs.
any help?
PostPosted: Mon Apr 07, 2008 9:28 pm    Post subject: Reply with quote
Is that running under nVidia "Dual" mode?
Do the UVs disappear when the graphics window is on either of the displays, or is it just one thats affected?
Is it only after "Optimize" that the UVs disappear, or have you seen it at other times? If you "Pack" after the optimize, then use the Home key to reset the view, do they come back?
Scubasteve
PostPosted: Mon Apr 07, 2008 9:37 pm    Post subject: Reply with quote
yes running in dual mode also tried the horizontal mode from reading the other threads
it does it for both sides.
and i havent seen any uv when i click optimize period and and no to the last question.
to add i had the student version from gdc about 2 years ago and it had the same problem but i updated the graphics card and it ran fine.I just updated to the hobbyist and it has the same problem so I just downloaded the latest driver from nvidia and i have the same optimize problem i had with the student version. if that helps
PostPosted: Mon Apr 07, 2008 9:53 pm    Post subject: Reply with quote
Sorry, more questions :-)
Is it doing this on just the one mesh, or any object? If you load the sample torus (double click the UVLayout desktop icon, then click on "Test" in the licensing GUI) do the UVs disappear after Optimize as well?
Scubasteve
PostPosted: Tue Apr 08, 2008 4:48 am    Post subject: Reply with quote
any mesh isnt working. except i can see the torus one perfect on both screens
PostPosted: Tue Apr 08, 2008 5:05 pm    Post subject: Reply with quote
"except i can see the torus one"
Ahhh, interesting ... are you able to email me one of your OBJ files? There could be something about your geometry thats causing the problem, because if the torus is showing up, then it means the graphics are working fine.
Scubasteve
PostPosted: Tue Apr 08, 2008 7:35 pm    Post subject: Reply with quote
i got it to work exported with quads thanks for the help though phil
cheers
user error haha
PostPosted: Tue Apr 08, 2008 7:41 pm    Post subject: Reply with quote
"i got it to work exported with quads"
So your objects were all triangles, or something else? I'd still love to see one of those OBJ's, because it does sound like a bug that needs fixing.
