problem with uvlayout in windows xp 64bit
zensview
PostPosted: Wed Aug 22, 2007 1:31 am    Post subject: problem with uvlayout in windows xp 64bit Reply with quote
I been using uvlayout for a while, it's really great for flatten the uv, reently i upgrade to a dual view LCD, and install the lastest uvlayout 1.21.1. somehow it keep crash when i switch from ed mode to uv mode. I did a test on signle view. but it still crash. any idea? ps I'm using nv 7950gt.
PostPosted: Wed Aug 22, 2007 1:42 am    Post subject: Reply with quote
Does it report any errors when it crashes? Other users have had problems with nVidia dualview systems, but they usually go away if the dual view mode is switched off, so I'm wondering if you have a different problem.
One thing you could do is to check that you have the latest available driver for your nvidia card.
zensview
PostPosted: Wed Aug 22, 2007 12:17 pm    Post subject: Reply with quote
I did load the lastest nv driver today, but it still crash. here's the error report.
PostPosted: Wed Aug 22, 2007 5:38 pm    Post subject: Reply with quote
Thanks for the stack dump! Looks like it could be the same problem (and solution) described in this posting ...
http://www.headus.com/phpbb/viewtopic.php?t=202
