64 bit
wr_uk
PostPosted: Mon Jul 23, 2007 10:37 am    Post subject: 64 bit Reply with quote
Hi
Am I right in saying the UV Layout will run on a 64 bit Machine?
Thanks
Wayne
PostPosted: Mon Jul 23, 2007 5:17 pm    Post subject: Reply with quote
The Windows version of UVLayout is compiled for 32bit, so it doesn't run as a natively 64bit application, but it does run on 64bit hardware as far as I know (i.e. it does here on my own 64bit laptop).
Theres both 32bit and 64bit compiles of the Linux version of UVLayout, but its been a few weeks since I built or tested the 64bit version.
wr_uk
PostPosted: Tue Jul 24, 2007 4:24 am    Post subject: Reply with quote
OK.. I just in the process of buying a new PC and I'm looking at 64bit running window 64.
sorry I don't understand this
So will UV Layout run on 64bit windows or not?
If not are there any plans to realease a 64bit version other than on linux
Thanks
PostPosted: Tue Jul 24, 2007 5:00 pm    Post subject: Reply with quote
"So will UV Layout run on 64bit windows or not?"
It will.
cushwa
PostPosted: Sat Oct 06, 2007 8:55 am    Post subject: dongle driver for Windows XP 64 Reply with quote
Which dongle driver would you suggest for Windows XP 64???
should I use the updated dongle driver for Vista or the old Windows dongle driver.
Thanks -tom cushwa
PostPosted: Sun Oct 07, 2007 4:55 pm    Post subject: Reply with quote
"should I use the updated dongle driver for Vista"
Yes, thats the most recent one, and worked here on my 64bit XP system.
