obj wont shows up on 3d view
rwijaya
PostPosted: Mon Apr 02, 2007 5:45 pm    Post subject: obj wont shows up on 3d view Reply with quote
my problem is exactly what the title says. any solution?
are the model suppose to already have a uv when i import it in? or i start with a clean slate?
thx in advance
PostPosted: Mon Apr 02, 2007 5:51 pm    Post subject: Reply with quote
So you mean the 3D view is completely blank? If yes, then it sounds like the OBJ isn't loading properly. Try "New" under the load options, which ignores any existing UVs and lets you start from scratch.
rwijaya
PostPosted: Mon Apr 02, 2007 7:56 pm    Post subject: Reply with quote
i'll try that, thanks for the quick response.
Update: its fix it. THX abunch, i will ask more if i have more issues on other part.
Its a KICK ASS software phil, you don't know how much time i saved using this tools.
i saw kevin presentation on saturday and it kick a nut sack of other uv layout program.
Other question, how do you move UV in uvlayout? i saw kevin smudge the UV, but i somehow couldn't find the hotkey for it.
PostPosted: Mon Apr 02, 2007 8:13 pm    Post subject: Reply with quote
Ctrl-MMB to move a single point, and Shift-MMB to move points using a circular brush.
rwijaya
PostPosted: Mon Apr 02, 2007 8:31 pm    Post subject: Reply with quote
THX PHIL!
moochie
PostPosted: Tue Apr 03, 2007 1:37 pm    Post subject: Reply with quote
And Ctrl+Shift+MMB to move all vertices within 4 vertices of the point under your cursor. Very handy for sorting out overlapping areas before smoothing with X or B.
rwijaya
PostPosted: Tue Apr 03, 2007 2:40 pm    Post subject: Reply with quote
thx, this is really helpful.
